How to create Hosted feature layer backups periodically
3203
6
05-06-2024 08:49 AM
JoseSanchez
Hello everyone,
How do you recommend to run periodical backups from a hosted feature layer ?
Several layers are editing a group of layers and we need to make backups.
Thanks
Tom_Laue
Geodatabase Backups
I recommend adding a Tag to any content you want to backup.
Then via Python script, you can download any content with that Tag to gdb and schedule the script (via Task Scheduler) to run daily or weekly as you need.
I use the tag: GDBNightlyBackup
import datetime
startTime = datetime.datetime.now()
TodaysDate = datetime.date.today().isoformat()
print (startTime)
import arcgis
from arcgis.gis import GIS
import os
#enter AGOL sign-in credentials
gis = GIS("https://yourorg.maps.arcgis.com", "username", "password",verify_cert=False)
now = datetime.datetime.now()
folderName = now.strftime("%Y-%m-%d")
#print (folderName)
parent_dir = r"C:\ArcGISOnline\BackupFiles\FeatureLayers"
path = os.path.join(parent_dir, folderName)
#create folder if it doesn't exist
if os.path.isdir(path):
    pass
else:
    os.mkdir(path)
    print("Directory '% s' created" % folderName)
def downloadItems(downloadFormat):
    try:
        download_items = [i for i in gis.content.search(query="tags: = 'GDBNightlyBackup'", item_type='Feature Layer',
                     max_items=-1)]
        #print(download_items)
        # Loop through each item and if equal to Feature service then download it
        for item in download_items:
            if item.type == 'Feature Service':
                print(item)
                result = item.export(f'{item.title}', downloadFormat)
                #r'file path of where to store the download'
                result.download(path)
                # Delete the item after it downloads to save on space
                result.delete()
    except Exception as e:
        print(e)
downloadItems(downloadFormat='File Geodatabase')
endTime = datetime.datetime.now()
td = endTime - startTime
hours, remainder = divmod(td.seconds, 3600)
minutes, seconds = divmod(remainder, 60)
TimeElapsed='{:02}:{:02}:{:02}'.format(int(hours), int(minutes), int(seconds))
print ("")
print ("Done!")
print ("")
print ("Ended at " + str(endTime))
print ("Time elapsed " + str(td))
The result is I have backup folders every day for all the hosted content I've been downloading.
emoreno
Hi Tom,
This code is very useful, thank you for providing it. I was wondering if you could provide insight on how it could be adjusted to add a FGDB item into a Backup folder in ArcGIS Online through a scheduled notebook, as opposed to scheduling a python script to export the backups to my C drive. If you are able to assist, I'd greatly appreciate it!
Thank you
Tom_Laue
JSON backups
Similarly, I also backup the content JSON files incase schema on a hosted layer gets changed or a webmap/dashboard/app gets inadvertently changed or broken.
ESRI webmaps, dashboards, etc. have two parts to their JSON data.
  • Description
  • Data
The Data is where all the customizations you’ve made to the content are stored.
The script is set to download all the following JSON Data for the following item types in your Portal:
  • Web Map
  • Web Mapping Application
  • Feature Layer
  • Application
  • Dashboard
  • Web Experience
  • item_types
If a new item of that type is added to Portal, a new folder is created from the item name.
If the content was modified in the last 24 hours, a new JSON file is saved.
import arcgis
from arcgis import gis
import json
import os
import glob
gis = arcgis.gis.GIS("https://yourorg.maps.arcgis.com", "username", "password")
import datetime
dateString = now.strftime("%Y-%m-%d")
folder_location = r"C:\ArcGISOnline\BackupFiles\JSON"
item_types = { 'Web Map',  'Web Mapping Application',  'Feature Layer','Application', 'Dashboard', 'Web Experience'}
for itemType in item_types:
    folder_name = itemType
    subfolder_path = os.path.join(folder_location,folder_name)
    try:
        os.mkdir(subfolder_path)
    except:
        pass
    print("\n"+itemType)
    itemType_items = gis.content.search(query="*",item_type=itemType,max_items=10000)
    listOfItemIDs = []
    for item in itemType_items:
        listOfItemIDs.append(item.id)
    for iid in listOfItemIDs:
        my_item = gis.content.get(iid)
        item_title = my_item.title
        removestring ="%:/,.\\[]<>*?$"
        item_title = ''.join([c for c in item_title if c not in removestring]).strip()
        file_name = item_title+"_"+itemType+"_"+str(dateString)+".json"
        file_path_item_folder = os.path.join(subfolder_path ,item_title)
        file_path = os.path.join(file_path_item_folder ,file_name)
        item = my_item.get_data(try_json=True)
        if len(item)>0: # only proceed if json dump is not empty
            try:
                #print(file_path_item_folder)
                os.mkdir(file_path_item_folder)
            except:
               a=1
            full_path = os.path.join(file_path_item_folder,file_name)
            #get date of newest file in folder
            list_of_files = glob.glob(file_path_item_folder+"\*")
            if len(list_of_files)>0:
                latest_file = max(list_of_files, key=os.path.getctime)
                newestFileDate = os.path.getmtime(latest_file )
            else:
                newestFileDate = 0
            #note:  does not run on empty folders with no json exports already
            if newestFileDate == 0 or my_item.modified/1000>newestFileDate   : # if modified date newer than last json or no json in folder
                print("\t"+item_title)
                print(full_path)
                with open (full_path, "w") as file_handle:
                    file_handle.write(json.dumps(item))
print("\n\nCompleted")
HanliePetoors
@Tom_Laue thanks for sharing this script.
What would be the process to restore the content if needs be?
Thanks
Hanlie
Tom_Laue
Hi Hanlie,
As far as restoring an item from JSON if you accidentally deleted it or if I just want to compare the current vs backed-up item, I create a brand new webmap or dashboard manually in Chrome and copy/pasted the JSON from the backup and overwritten the existing JSON using https://ago-assistant.esri.com/.  Problem with that is you'd get a new item ID which could break other things like scripts or links you'd already established.
I've used the script mostly to:
  1. See what items in my ORG were changed when and have a log each day to refer back to or to restore back to
  2. If an item really got screwed up, I would go into AGO Assistant and replace the json with the backup json and see if that fixed the item.
I go in AGO Assistant.  I search for the item (by default it only display items you own) by name or itemID.
Find the item and in the dropdown choose I want to...View an Item's JSON
Replace the Data of it's json with the .json file you have backed up on your network.
Hit save and then view that item in Chrome or Field Maps.
HanliePetoors
Thanks Tom, your instructions are very clear. This will help me a lot.
Regards
Hanlie
