How to create a data extract tool used to extract data in two different coordinate systems?
1993
10-06-2016 06:45 AM
DanielChantlos1
We have a published geoprocessing service (data extract tool) on a WebApp website. We would like to know if it is possible to add an option that allows users to extract this data in 2 different corrdinate systems (GCS/PCS) on the WebApp using our published data extract tool.
AdrianWelsh
MVP Honored Contributor
Daniel,
That sounds like a useful and interesting tool. How is it extracting right now? Is it just taking the default coordinate system of the web map? Or are you coding in the system? What language are you using to program this service?
RussRoberts
Esri Notable Contributor
If you are using create replica on a feature service you can set the export spatial reference and the output type.
DanielChantlos1
Does create replica work on ArcGIS Online/WAB?
RussRoberts
I have really only used it through REST directly or through Collector. I dont know of a custom widget for WAB that achieves this today.
