How to combine an IF statement inside a for loop in Arcade ?
2638
06-30-2020 01:29 PM
by Anonymous User
Not applicable
Hello,
I have an array of numbers (around 800 numbers) var mylist = [604703,607006,607606,607607,.................]
and I have a Number datatype field in one of my layers. I want to see if the data inside this field match any of the numbers in mylist? and when it does it will say for example " Matched " if does not " No Match".
Thank you.
KenBuja
MVP Esteemed Contributor
You can use IndexOf to determine whether an item is found in array
if (IndexOf(myList, feature.$Number) > -1){
  return "Matched";
} else {
  return "No Match";
KenBuja
  return "Matched";
} else {
  return "No Match";
by Anonymous User
Not applicable
Thank you so much @ken buja ! it worked !!   I was able to use it in the configure popups and in symbology expressions !
JoshuaBixby
Not that this is any better than Ken's answer, just a slightly different code structure:
IIf(IndexOf(myList,feature.$Number) > -1, "Matched", "No Match");
by Anonymous User
Not applicable
Thank you @Joshua Bixby ! It worked !
by Anonymous User
Not applicable
Both @ ken Buja and Joshua bixby's code worked with me !!!
