How to ArcGIS in attributive table restore data after replacing the field?
925
04-15-2013 11:32 PM
marijanatomic
How to ArcGIS 10 in attributive table restore data after replacing the field with the field? After using the field calculator? Please help, I lost a lot of data!!
RobertBorchert
Honored Contributor
As far as I know the only way get it back is to NOT save it after doing the field calculator.  Unless you are in an SDE database than you may be able to recover it.
The second best option is that have  made a regular back up of your data and to recover that recalculated column from the backed up data.
