How to access Report Graphic Elements, Text Elements and So on using ArcPy?
1279
11-10-2022 08:06 AM
Labels (3)
PandiyanKesavan
I am working on Report Generation. I can able to change the data source and export it as PDF in a Report Template using ArcPy.
I want to access Report Elements or MapFrame and change that using ArcPy. These options were available for layout. but I could find for Report.
If anyone tried the same or found something, please share.
PK
DanPatterson
MVP Esteemed Contributor
There are only 3 areas for reports exposed in mp.CIM
Report—ArcGIS Pro | Documentation
ReportLayoutSection—ArcGIS Pro | Documentation
ReportSection—ArcGIS Pro | Documentation
maybe you can find what you need there
... sort of retired...
