How do I update the default table name in AGO?
1369
06-27-2017 06:10 AM
janispaulsen
I updated the name in the table of contents and updated the name in the pop up configuration, but the table name defaults to the original feature layer name. I want the table name to match the name in the table of contents.
KellyGerrow
Esri Alum
Hi Janis,
Is this a hosted feature layer or a Map Layer hosted on ArcGIS Server? Are you able to share the the web map?
-Kelly
janispaulsen
Yes, it is a hosted feature layer.  The map is public but it’s locked down.
I have the same layer 4 times in the TOC and have time period filters applied to each copy.  Each layer is has been renamed with the layer name and the time period it reflects.  I want the table name to reflect the TOC name including the time filter, which is in the name of each layer in the TOC.
