how do I save as a shapefile
2180
05-02-2012 10:23 AM
LindaIrving
Help! --I have a little map,
http://bit.ly/Ivb28S
and would like to save the polygon as a shapefile, to use it to order a sat photo.  How do I do this??
The vendor says that she cannot see geographical information on my file.
with gratitude,
L (novice user of ArcGIS)
MikeMinami
Esri Notable Contributor
There is no capability to export a 'map notes' layer to a shapefile.
Anyone who opens the web map should be able to see the layer. I'm not sure why your vendor can't.
Mike
JoeFlannery
Honored Contributor
whirving2012:
You could use ArcGIS Explorer Desktop to draw the same "Map Note" of your area of interest.  Then right-click on the map note polygon and use the Share to KML to export your AOI.
