How do I put new update data automatically connect to existing web map? On ArcCatalog, service workspace: I noticed the tab has copied and not on referenced. How can I fix this from copied to referenced? Also, every time I try to put new update data but w
8165
12
06-15-2017 08:06 PM
AlexP_
How do I put new update data automatically connect to existing web map? On ArcCatalog, service workspace: I noticed the tab has copied and not on referenced tab. How can I fix this from copied to referenced? Also, every time I try to put new update data but web map still keeps the old data. I need it to be automatically every time update new to web map. Please assist me in this matter step by step. Thanks
AlexP_
****The web map is already "publishing from ArcMap to a GIS Server site; then referencing the web service in your web map".
DerekLaw
Esri Esteemed Contributor
Hi Alexis,
Apologies for the late reply - when you posted, it was during the esri UC week and it was pretty busy. Even a week later, I am still in the process of catching up on emails, etc.
> Do I have to connect story map from web map and would it connect automatically data whatever save to "Story Map Tour"?  Would it work? I have a difficult to find resource.
I am not 100% clear on what you're asking. If you publish content to an ArcGIS Server site from a valid data store, then the data would not be copied to the Server. Next, you add the web service as a data layer in a web map. Then you create a Story Map app for the web map. Is this workflow correct? If so, then yes - the Story Map app should be able to access the resource.
Hope this helps,
AlexP_
Yes. Correct. I am appreciated for your response. Thank you!
