How can I put this data in?
1048
10-16-2011 12:09 PM
DillonKnackstedt
Basically I am trying to map out the costumer base of our company Leave a Legacy.  In this case the data would be by zipcode and I want it to display the # of people in that area.  Though I have been unable to find a way so am I just going to have to put in addresses individually so its more of a cluster, not a chloropleth?
KieranFitzsimmons
I am sure you could use  locators within ARCGIS 10 to do that all for you , as the locators would be able to geocode the address that you have in your database, which would display a point on the map symbolising the address record.
hope that helps
MikeMinami
Esri Notable Contributor
If you can summarize your data and create a CSV file with one record per zip code, you could plot this on a map using ArcGIS Explorer Online. Explorer Online will allow you to geocode 250 points or less using the zip code alone. The points will be located at the centroid of the zip code boundary, I believe.
hope this helps,
Mike
