Hosted Feature Layer view can't be updated with new fields
7895
18
05-02-2022 01:10 PM
HBottelberghe_eci
Hi all,
I'm working with a view of a hosted feature layer. I added new fields to the hosted feature layer. I made sure the new fields are visible in the table of the hosted feature layer. But when I go to 'Update View' for the view layer from its Settings tab, the new fields are not available in the list of fields available when I click 'Select Fields'.
Has anyone encountered this problem with adding fields to the view layer definition and can't find them even if they are toggled visible for the source hosted feature layer? Were you able to resolve the problem, if so - how did you resolve the problem
Heather Bottelberghe
ChelseaRozek
MVP Regular Contributor
New year, problem is still here. I can't even make a new view on the hosted feature layer to try and remake it.
Update: I deleted the view and tried to make a fresh, new one. Found a solution over here: Solved: Re: "Failed to create layerview for layer title: <... - Esri Community . If you allow "Editors to see all features", switch over to edit your view, and then turn it back to "Editors can't see any features, even those they add" I was finally able to edit a view. I wish you could do the administrative task of setting up a view without making the private information completely public (it's a public facing Survey123 survey).
ErikHerbergMETC
Update - I still have this issue from time to time as well after adding a new field. One trick that sometimes works, sometimes doesn't, is to add data into that new field in the feature layer, in particular the bottom (or most recently added) row. I've done this by waiting until a new Survey123 entry is submitted or by manually adding an entry in the last row. It seems like once some data gets added, the field then appears as an option to add to the view soon after. Again though, I haven't tested to see if this trick always works or not, but might be worth a shot.
NinaRihn
Darn, that sounded promising, but I tried it, and it didn't work for me...thanks for sharing though!
RichardRogers1
I'm just stopping in to show my support for finding a resolution to the problem.
Very similarly, I've decided that I needed an additional field in my S123.  Added it in 123Connect then republished.  Everything went smoothly until I decided I also needed to add that new field to the views.  As is common in AGOL, there are several possible places where a person might think this task could be handled... I tried all that I'm aware of, but was unable to add the field to the views (internal and external facing datasets).  I gave up, created new views, added them to the maps, went through creating the symbology in each map, recreated all the labels in each map, and modified all html popups as I needed them.  This is a lot of trouble to go through just to add a field.
I'm assuming this is a schema level issue that's likely a deeper problem that it seems on the surface.  That being said, it's a problem that needs a solution if I plan to move forward using S123 as a solution for our electronic forms.  Inevitably, forms will need to be edited over time so we must have a way of simply adding a field to a view without rebuilding the layer in each map every time.
Cheers.
MichaelKohn_PGE
I am not sure if there's been a solution to this issue yet but I tried something that fixed the issue on a layer I just published to AGOL from ArcGIS Pro then had to add a field to the hosted feature service in the data tab in AGOL. The hosted feature view was not allowing me to set the newly created field as visible in the settings tab in AGOL just like what was described in this thread. Note that the new field I added did NOT allow for null values to be entered. (I don't know if this has something to do with why my work around worked)
My work around was this:
In the hosted feature view, I deleted the newly created field then added the same field but ALLOWED null values to be entered (I figured that I would just make this field required in Field Maps and the Web Map form)
After re-adding the field I went into the settings tab of the hosted feature view to update the view and the field was able to be selected.
AdamTerrell
I can say this is still an issue in 2024. I am using the ESRI Lead and Copper solution and my field crews need to designate meter titles that require a vacuum truck to verify the service lines.
I created a new field in the hosted feature layer called "Clean Needed" and updated my three views. The new field and domains appear in two of my three views. Unfortunately, the new field is not appearing in my field crews' view.
I hope creating a new view does not destroy our field map, web applications, and dashboards. I inherited this project from my predecessor and I consider myself a GIS rookie.
AdamTerrell
I figured out my issue!!! 2 hours of reading!!!
When "updating view" from the settings page of the view layer.
I was just selecting the layer and then selecting Next --> Update
I can't recall if I found this link in another community post or google search, but it lead me to my solution.
https://support.esri.com/en-us/knowledge-base/problem-hosted-feature-view-does-not-inherit-new-field...
After selecting the layer, select define view.
Expand the layer.
Expand the fields
Select your missing field, then update. My other views showed the new field so I figured something was just not working.
Juan_Toro-Killion
Has anyone encountered this problem, but been unable see/have the "fields update" icon available to them? Happens repeatedly for me in Portal 11.3.... This is pretty big issue for me, as I'd prefer to NOT have to create new view layers after updating the schema of a feature service. @HBottelberghe_eci
ZoevdbAT
Yes
