Heat map using only locations in new Map viewer
2544
06-10-2021 04:27 AM
TórshavnarKommuna
I am trying to create a heat map using only point locations, in new AGOL Map viewer. But I have to choose an attribute, before the heat map option is available under the symbology settings.
Is there any way to create a heat map which only uses point locations?
Tags (3)
JayantaPoddar
MVP Alum
I am able to change without attribute.
Sometimes, you may need to zoom in/out for the change to reflect on the map.
How does your Style Pane looks like (screenshot)?
Think Location
JayantaPoddar
MVP Alum
Think Location
TórshavnarKommuna
Thank you for letting you know that it works for you.
I have tried again, to remove the attribute, and now for the first time it worked. I didn't get the messege "The layer is not providing enough info....". Even though I have tried to zoom in and out previously, as you suggested.
Problem solved 🙂
