Heat Map symbology shift and move on Esri basemap when zooming in and out
1388
12-11-2023 11:18 PM
ElieRizk
we are facing a strange behavior (shifting, jumping) with a web map shared using ArcGIS Pro 3.2 to the enterprise portal, I attached a video showing two maps:
  1. the first map doesn't have this issue, where I am using the event theme layer reading from a SQL view with unique value symbology (using 3 fields).
  2. the second map has the same data source with one difference being that I am using heat map symbology.
when zooming out to infinite zoom the heat map goes out of its initial extent as shown in the attached video.
I am not able to sort out the behavior behind that noting that I am using ArcGIS Enterprise 11.2 and Pro 3.2
JeffreyThompson2
MVP Frequent Contributor
I have seen the symbology lag sometimes when panning a map causing it to draw in the wrong location. Does the problem correct itself if you leave it alone for a few seconds?
GIS Developer
City of Arlington, Texas
ElieRizk
No, it remains at the last location, until I zoom out two steps further it will back to the correct location.
thanks.
