Getting Started with Changing AGOL templates.
882
05-20-2013 03:19 PM
DianaUmpierre
Need some "basic" help to get started on making minor edits to a Web Map Application made using the One Pane template. How do I get started on changing things like the following?
- change the banner
- change the background color of the "one pane" that shows map description
- making sure that links on the map description open on a new browser window (or tab) versus the same window (which is what appears to be default).
The "Configure App" is too limiting and the other templates aren't that much more flexible.
I have ArcGIS for Organizations, if that helps. The idea is to keep the app as hosted by ArcGIS online, not poiting to our own URL. Basically, I don't have an external web server to host this app, but I don't know how to get around the limitations of the templates without downloading the entire code and publishing in a separate server.
Is what I want even an option?
MikeMinami
Esri Notable Contributor
The template support limited configuration. If you want to do something you don't see in the settings to configure the template, then it's not available. The only option is to download the code, modify it, and host it on your own web server.
Mike
