GeoService widget red x
959
05-31-2017 01:54 PM
by Anonymous User
Not applicable
I have a file of 2,000 records to run in the GeoService widget.  The widget is set up to accept 100,000 records with a grouping of 1,000.  It is checking the file against 4 layers and will not complete.  It gives red X everytime.  I have modified and tested the numbers for records and groupings but noting is affecting the outcome.  Does anyone know what else it could be?
Tags (3)
KellyGerrow
Esri Alum
Can you share a screenshot of the issue that you are running into or the app that you are using? Is it an app built with Web AppBuilder or a configurable app?
Kelly
