Geoform - Why are un-enabled fields still showing up in my GeoForm?
1352
07-27-2017 12:23 PM
RobinPatton1
We have created a layer for reporting of historic sites.
We want to build two geoforms off the same layer - one that is a quick survey and uses some of the fields and another that is a complete survey and uses all of the fields.
we want the submitted data to reside in the same data layer so quick surveys can be updated with the full survey if warranted.
When we try to build the short form and uncheck enabled for the detail level fields, they are still generated in the GeoForm.
Even if we hide the detail fields in the underlying map document, they still show up in the field list for the GeoForm and in the resulting form that is generated.
App is public and can be viewed here:
GeoForm
by Anonymous User
Not applicable
Hi Robin,
Are you able to explain a little more what you mean by "Even if we hide the detail fields in the underlying map document"?
KennethBusby
I am having the opposite problem where enabled attributes are not showing up even though they are required fields.
