Fire Fox Swipe Pop Up Bug
2904
5
09-24-2013 10:29 AM
AmandaDeMedeiros
There is a problem when I try to use the swipe over a pop up in Fire fox. It works fine in Google Chrome or Explorer.
Below is a link to the application I am creating. Would be nice to have a work around before the Nova Scotia general election, Oct 8, 2013, so I won't have to tell users to not use Firefox.
http://www.arcgis.com/apps/StorytellingSwipe/index.html?appid=7a5266f3c14640b485e7f640f6aed6f6&webma...
Amanda De Medeiros
Esri Canada
MichaelVolz
Esteemed Contributor
Can you explain what the problem is as it appeared to work the same in IE and Firefox?
AmandaDeMedeiros
The issue happens when you click on the 2013 side. No pop up appears in firefox, it also doesn't appear if you click 2009 then swipe to 2013.
Amanda De Medeiros
Esri Canada
MikeMinami
Esri Notable Contributor
I can reproduce the problem. We'll need to investigate it.
Mike
AmandaDeMedeiros
Was this issue ever resolved?
Amanda De Medeiros
Esri Canada
MarkCooney
We have identified and fixed the issue, but unfortunately the fix will not show up in AGOL hosted apps until the next release.  If you are able to host the applications yourself, you can download the updated code from our github (https://github.com/Esri/swipe-map-storytelling-template-js).  Hopefully this will work for you, sorry for the inconvenience.
Regards,
Mark
