Filter using two date fields
1267
10-20-2022 10:51 AM
Labels (3)
Jan_VincentPunzalan
Hello, I am creating a filter for an ArcGIS online web map and need to compare two date fields as part of the query. Is there a way to do this in AGOL? I think it's possible on a dashboard but not on a web map?
In ArcGIS Pro here is the query I'm trying to get to work in AGOL:
Tags (3)
Clubdebambos
MVP Regular Contributor
Hi @Jan_VincentPunzalan
If using Map Viewer Classic, use the filter for the layer in the table of contents on the left and use the Add another expression option. Set toe Display features in the layer that match all of the following exprssions. Click Apply Filter
In new Map Viewer select the layer on the left and then use the Filter option on the right of the screen. Click Add expression options and in the Filter results drop down set to Match all expressions, click Save.
~ learn.finaldraftmapping.com
