Field Map Errors Trying To Create Map
89
Thursday
MarkBinder
I am trying to create a map that I can look at when I go hiking; many of the layers have been created by another party and are available on ArcGIS Online. I am unable to change this map to work offline because all of these layers give a "missing global ID" error.
Is there any way to get these layers working? Or do I have to own all of the layers in order to take this map offline?
Katie_Clark
MVP Regular Contributor
If the layers don't have globalIDs, it sounds like sync probably isn't enabled on the layer, which is required for offline capabilities.
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
