Feature layer won't enable for editing in app
3167
11-27-2016 05:15 PM
KateMarkiewicz
I've been having issues creating a collector app I created from a map. I have editing enabled in the feature layer as well as in the map, but when I create an app and go into the edit widget there is no layer to add features to. Does anyone know what I'm doing wrong or missing?
Kate
Editing widget not showing any layers to add features toEnabled editing in the feature layer detailsEditing enabled for layer in map viewer
DerekLaw
Esri Esteemed Contributor
Hi Kate,
From the screenshot your provided, it looks like a Web AppBuilder app - is that right?
When you add the feature layer to the ArcGIS Online map viewer, can you make edits?
KateMarkiewicz
Yes, it is a Web AppBuilder app.
I can make edits to the feature layer in the map viewer.
DerekLaw
Hi Kate,
So after you've added the feature layer to the web map (and the feature layer is editable), did you save the web map, then open the web map in Web AppBuilder? Once you add the Edit widget, the feature layer should be available and accessible in the Edit widget.
Hope this helps,
