Feature Layer with calculated fields
1156
11-18-2021 06:59 AM
Bud
Legendary Contributor
In ArcGIS Online, is it possible to create a feature layer with calculated fields?
For example, if there is a CLASS field with the value 'A', is there a way to dynamically concatenate 'A' || 'B' as a CLASS_CONCAT field (value='AB')?
And then serve that up as a dynamic feature layer for integration purposes (not a one-time thing).
I'm hoping it's possible to do that without the need to import into ArcGIS Enterprise as an intermediary step.
Thanks.
Jing_Sun
Hi, I think Notebook can be used to achieve this. You would need a Python script for the operation on feature service, and then schedule that task to run on a recurring basis.
