Feature editing working for some fields not others
676
01-17-2023 09:02 AM
Labels (3)
IS_SpatialHub
I'm using ArcGIS Online to edit a Hosted Feature Layer.
I've edited the layer settings so that the features are editable.
I wanted to add some data for values that are blank at the moment - I was able to add data into some of the blank values. I can still go back and change the data that I've added to those blanks, suggesting that the data is still editable.
However for some of the blanks, when I try and add data, it simply returns an error and doesn't save the new text. The same thing occurs whether I attempt to edit the layer in 'View Item Details' > 'Data', or whether I open it in either Map Viewer or Map Viewer Classic and try to use the editor function. Same 7 blank values that I can't add any text into!
These are also all in different fields that it previously let me edit, and still lets me edit for some values. I know that it is possible to make some fields editable and not others, but I've checked my settings and don't think that's the case here.
Any clues as to why this may be happening would be appreciated!
