Export hosted feature layer domains to table.
2903
05-22-2023 11:29 AM
Labels (2)
luckachi
I need to export a few domains from a hosted feature layer but there does not seem to be a way to do this in ArcGIS Online or Pro? Please advise as Domain to Table Geoprocessing does not allow me to select the correct Input Workspace.
jcarlson
Exporting the layer should include the domain if you copy it into a file geodatabase, then you'd be able to use that in the Domain to Table tool. You could also just go to the feature service's URL, append a ?f=json and then extract the domains objects from the service definition.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
luckachi
Thank you @jcarlson - I did have it exported to a FGDB but for some reason it was not letting me select anything. Also didn't realize that  the actual .gdb file could be selected as the workspace 😅  Thanks again.
