ESRI_Anonymous Last Edited User
2128
01-27-2020 02:42 PM
LeviCecil
I have a feature service in an Enterprise sde that is published to our ArcGIS Server. This layer lives in an AGOL web map that we use Collector to edit and update. The issue is that when I perform edits, the last edited user is "ESRI_Anonymous." I found this article from 2016 that suggests two workarounds. Neither of these work for us. We don't want users to have to log into Collector and then log in to the Server to load the data. The app will not get used if this is the case. We can't publish this as a hosted feature layer, because we need edits to show up immediately in our sde, not just in AGOL. We need to know who is editing the services and when.
Has this issue been addressed since 2016?
Tags (1)
BillFox
MVP Notable Contributor
BillFox
Hello Levi,
is your agol setup for single sign-on to your on premise ad?
LeviCecil
I'm not sure. Should we be logging into Collector with Enterprise login instead of through AGOL?
BillFox
saml
LeviCecil
OK. I think that's in the works with our 3rd party GIS Server host. Thanks!
