Error when setting up tile layer pop-ups
2305
09-28-2016 07:45 AM
MichaelKnapp
Hi there -
I hope I'm missing something simple here, but I'm having issue activating pop-ups on a new tile layer in ArcGIS Online. Whenever I try and do so, I receive this:
However, the tile layer does have attributes.
The method I'm using is:
1. Create a tile package from an MXD (File--> Share As --> Tile Package)
2. Uploading to ArcGIS Online, then publishing from there.
I suppose it's possible there's an issue with the MXD and I should rebuild from a new MXD and try publishing again, but also wanted to see if anyone else has had this issue.
Thanks!
MaryLong
Hi Michael,
According to the help documents for building a tile package and publishing it to ArcGIS Online, you will have to specify a feature layer with the hosted tile layer if you want to configure pop-ups. (Build and share a tile package in ArcMap and publish)
Hopefully that helps to answer your question!
MichaelKnapp
Actually, I'm thinking that I need to have a feature service for layer(s) for which I need to see attributes as popups, then link the tile layer pop-up to that feature service. But I'm leaving this question up for now just in case.
MaryLong
Hi Michael,
MichaelKnapp
Thanks Mary... that is exactly what I needed to do.
-Mike
