Error Publishing a Map Service for ArcMap to ArcGIS Online
33994
42
06-20-2012 02:45 PM
AdamInglis
I have been through the process several time and I keep getting a very generic error message when I try to publish a service that I uploaded from ArcMap.
The first warning I get is when publish from ArcMap, cache generation failed:
[ATTACH=CONFIG]15384[/ATTACH]
The service uploads without an issue, but when I view it online and try to publish it there I get this message, "There was an error":
[ATTACH=CONFIG]15385[/ATTACH]
Tough message to troubleshoot, any suggestions?
Adam
MikeMinami
Esri Notable Contributor
Ryan,
Can you toggle your organization from SSL to non-SSL and back to SSL? You may need to sign in/out in between. Hopefully this will clear up the problem.
let me know if it works.
Mike
by Anonymous User
Not applicable
Original User: lcbpgis
Success! That seemed to do it. I had to click the Publish button on the details page to generate the tiles.
Thanks, Mike.
TiffanyPuett
It also makes sense that you may need to log back into ArcMap as well. I had trouble until I did that.
