ERROR 001270: Consolidating the data failed.
66755
61
07-30-2012 07:43 AM
YimanSong
I got this error when I try to publish a tiled map service to ArcGIS Online through ArcMap. Does anyone know why?
by Anonymous User
Not applicable
Do you know how I could do this on ArcPro? Still new to navigating around in there. Thanks!
AmberShows
That's what worked for me as well, thanks Will Schulte.
KeG
I'm getting this error now too. I'm publishing a gp tool with a py script. My data is an empty gdb that i'm only using to get a schema into one of my gp tools.
I'm telling it not to move data. But it still busts with this error.
BenAller
I just got this error too.  I published a map document as a service about 2 months ago without any major problems.  This morning I attempted to republish the same map document with no changes except for editing capabilities.  The error shows up, and I retry a couple times and get the same error msg.  Then after read this thread, I went back and tried again to publish and it worked.  The only thing I did differently was to preview the service first.  Got me.....
TracyBusby
I was told that the service does not like versioned SDE.  Best to export to personal or file geodb before publishing.:cool:
Can anyone help me with a viewshed analysis?
JasonLyon
this error came out of the blue yesterday, have tried changing the staging folder with no help, cleaned out more storage space - no solution.
Can not overwrite an existing service, nor can I publish new service.
Very frustrating.
GIS-Cambria
I'm having the same problems with this error. I'm trying to publish to ArcGIS Online, using 10.2. I've changed the staging folder, etc.
MikeMinami
Esri Notable Contributor
There are a few possible reasons why consolidation fails.  These are the most common reasons we have seen.
  1. Low disk space.  Change your staging path.
  2. License doesn�??t support copying data.  For example, you try and consolidate (which is copying) data like a network or a terrain and you don�??t have the appropriate license level.
Mike
SorrenMills
Seen this happening several times and on several different systems for no apparent reason. Just lately, it has started occurring on a system that was previously working a week ago, so now I have a bunch of map services published that I can't overwrite nor create new services.
1. I have Advanced license level
2. I have over 50GB on both C and D drives - switching the staging folder to either makes no difference.
3. Tried renaming path names etc. but no luck.
Strangely, I have 3 MXDs that publish fine and 3 that refuse to. I can't see any differences to indicate why some work and some don't.
AlisonFletcher
Could I be getting this error if my dataset were too large?
