Elevation Layer via URL
1448
03-08-2023 04:36 AM
TH1
Hello together,
i want to load an Elevation Layer from a Portal to an ArcGIS Online via URL. It works fine until now, AGO won't create an Elevation Layer anymore it creates an Imagery Layer.
Something changed? Somebody know the Problem?
Thx for some help
Orginal Layer in the PortalOrginal Layer in the Portal
New hosted Layer in AGO via URLNew hosted Layer in AGO via URL
MJBiazar
Hi @TH1
It seems like this issue was introduced with the February release. A defect has been logged against this behavior (BUG-000156413).
In the meantime, you can work around this issue by manually adding  "Elevation 3D Layer" to the  "typeKeywords" in the JSON of the item using ArcGIS Online Assistant.
Please keep in mind that ArcGIS Online Assistant is not a supported product.
Best,
MJ
MJBiazar
Hi @TH1
Best,
MJ
