EDN license and arcgis.com
1007
03-01-2012 08:55 PM
ZorbaConlen
Does anyone know what, if any, limitations there are with arcgis.com and an EDN license? Wondering if you can create map services, feature services, etc... and publish them to arcgis.com?
Thanks.
MikeMinami
Esri Notable Contributor
What do you mean by "limitations?"
You can publish references to services that are hosted on your ArcGIS Server and use them in ArcGIS Online
In the future, you'll be able to publish your data directly to ArcGIS Online and access it as web services. This is part of an organizational subscription.
http://www.esri.com/software/arcgis/arcgisonline/index.html
Mike
ZorbaConlen
Thanks for reply Mike.
What I mean by limitations is that EDN is just meant for development and testing, so I wanted to make sure there is no restriction about EDN services on arcgis.com. It sounds like its not an issue, from your response.
