Dynamically assign graduated symbology based on the highest and lowest values
1185
11-19-2024 12:05 PM
Labels (3)
JonathanHeck2
I have an Experience Builder app that needs to have polygons symbolized by a graduated color scheme, but the catch is, the field that the values are based on will change over time. So I can't set a maximum value of "5", for example, because eventually the values will exceed 5. It needs to just be "the highest value" is red, and between 1 and "the highest value" is a graduation of colors between green and red.
The data involves municipalities with a survey and a layer with the Counts of Surveys field is used for the symbology. So as more surveys come in, the symbology needs to update the municipalities with a gradient color scheme showing more surveys = red, less surveys = green, and a gradient of colors in between. That's why the upper limit can't be a defined value.
Is this possible?
Laura
by MVP Regular Contributor
Have you left the max value to auto and not messing with it and then adding data to see if it is dynamically changing it?
