Dynamic Date Filter - Explorer & Collector
605
09-10-2020 12:18 PM
AshleyHayes2
I am currently using a dynamic date filter (in this case my filter is "not in the last" 6 months) to filter a layer in an ArcGIS Online web map.  This works just fine and the layer draws as expected in the web map with the features appropriately filtered.
However, I have noticed that when I open this map in Explorer or Collector, the layer does not draw at all.  The layer appears in the Table of Contents, but turning the layer on does not result in any features being drawn.  If I remove that dynamic date filter from the layer in my web map then there are no issues in Explorer and Collector.
Is this expected behavior?  If so, is there a recommended workaround?
Thank you!
