Domain values not appearing in form in web map
727
01-28-2026 04:51 AM
RandyMcGregor_BMcD
I added a field to a hosted feature layer view and created a domain with two values, 'Archaeological,' and, 'Tribal.' I added this field to a field map form. When I add a feature using the field map app, I see this drop down. When I add a feature in ArcGIS Online, the values must be entered manually. We will be adding features both in the field with field maps and directly in ArcGIS Online.
This is what the field entry window looks like for other fields that have a domain. The field entry window  for the field I added does not have this indicator in AGOL. The field map does, and users can choose values. Is there a setting that I am missing?
Thank you,
Randy McGregor
IssyAmis
Hi @RandyMcGregor_BMcD
You would expect the domain list to carry over so sounds like somethings happened with the field. Did you set up the domains within Field Maps?
If you take a look at the data tab for the layer and navigate to the specific field in the "Fields" tab to the left, do you see a domain list set up for the field?
RandyMcGregor_BMcD
Thank you for your reply. The domain was set up on the hosted feature layer in ArcGIS Online. I do see a domain list in the fields information for the layer:
There is no drop down option in ArcGIS Online, but there is in the field map:
