Domain Description From Another Layer
1565
09-14-2023 07:47 AM
JoshBillings
I am trying to return the domain description from another layer using an Arcade expression. I've tried the below, but it returns blank. Any tips?
var basinPoly = FeatureSetByName($map,'Modeling_Basins')
var d = DomainName(basinPoly, 'BasinID')
return d
Thanks!
KenBuja
MVP Esteemed Contributor
Unlike the DomainName function for a Feature, you'll have to provide the code to get back anything for FeatureSets
HMarcks
I am trying to solve the same problem.  Did you figure anything out?
https://community.esri.com/t5/arcgis-field-maps-questions/smart-forms-field-calculator-domain-from-n...
I can get it to return the domain code and am thinking I might have to set up a series of if statements to change the code to the description.  It wouldn't be pretty but I am not getting any more ideas on it.
AiminFan1
Any update on this issue other than hardcode the domain name?
