Does exposing your Bing maps Key in a public web map pose any real risk?
2632
10-03-2014 10:20 AM
C_EHoward
I want to have a nicer looking basemap for a public facing web map/app. I know I can use Bing since we have a key....but the help doc for AGOL warns that your key will be exposed if you enable the ability. What does that really mean? can others then use your key in their web apps?
ChrisWhitmore
For anonymous users to access your Bing maps, they need to be able to access your Bing key without authentication - meaning your Bing key is publicly available. Being that it's publicly available, it is possible for others to obtain your bing maps key and use it in their own applications. Bing maps website has this behavior as well..their Bing key is passed in clear text.
A couple things you can do to prevent usage by other applications (likely similar to procedures employed by Microsoft to prevent unauthorized usage):
1. The link below has instructions for viewing usage. If you see any unexplained usage, change your bing key.
Understanding Bing Maps Transactions
2. Change your bing key regularly. Up to you to determine how necessary this is (maybe check usage every so often and see if it appears anyone has grabbed your key?) From the www.arcgis.com perspective, all maps and hosted apps will be updated by changing the bing key in your organization settings. So you'd only need to make the change in one location. For any apps you've hosted locally, you'd have to check the specific configuration.
Chris
ChrisWhitmore
Chris
C_EHoward
thanks for the info & advice
