Develop Web Appbuilder for Arcgis
1294
11-07-2017 11:59 AM
MatKINH_IG
By default, portal for arcgis has widgets that cater to the needs of the majority of organizations, but for my organization, I need to change it accordingly.
For example, rename the attribute fields in the "i18n" folder, and then I continue to restart the portal but the edit is still unchanged?
I want to develop more widgets for my organization, but I frequently encounter id_client errors, so where do I need to find id_client information?
my portal: portal.capnuocnhabe.vn/portal
Thank you very much
DerekLaw
Esri Esteemed Contributor
Hi Mat,
You should not be modifying any internal files for Web AppBuilder for ArcGIS that is embedded within Portal for ArcGIS. Any changes are NOT supported and would violate your software license agreement for tech support, as you would be changing the internal Portal for ArcGIS software files.
Please use Web AppBuilder for ArcGIS Developer Edition to work with your Portal for ArcGIS instance and enable your custom functionality in Developer Edition.
FYI, Web AppBuilder for ArcGIS now supports Custom Widgets in ArcGIS Enterprise 10.5.1 | ArcGIS Blog
Hope this helps,
RebeccaStrauch__GISP
