Date field missing as an attribute in Style properties.
2675
03-28-2016 11:52 AM
MayaDaurio1
A hosted feature service layer has a Date field that is missing in the dropdown selection menu when trying to change the style (symbology) for this field. All other fields from the layer are present in the dropdown. I have also tried adding it as a feature layer created from its own File Geodatabase and get the same results. I need to be able to symbolize based on this Date field in this layer. Any ideas? Thanks.
AdrianWelsh
MVP Honored Contributor
Hi Maya,
It looks like you cannot symbolize (change style) based on a date field in ArcGIS Online. You may be able to create the symbology on the desktop end when you publish it. And you may want to make a string field (or numeric field) that would reflect the records in your date field.
Best bet is to make three different numeric fields (month, day, and year) and then you can change the style in ArcGIS Online freely of these three fields.
There are really a lot of combinations you can do in order to get around this hurdle. It will all depend on your application and what you need to do.
MayaDaurio1
Thanks for your help, Adrian.
