Custom URL parameter for Crowdsource Polling
1132
04-09-2020 11:01 AM
BMCGIS
I am configuring the crowdsource polling template.  This is the AGOL version, not the one you download.  I am trying to configure the custom URL parameter.  There are two options to choose from:
SELECT FEATURE - "Use a URL parameter to open the application to a specific feature without changing the visibility of features in the list or the map.‎"
FILTER LAYERS - "Use a URL parameter to filter the map and list to show only the features that have the provided value in the selected fields.‎"
The filter layers option works fine, but ideally I would prefer the first option where the feature I choose is selected but you can still see the surrounding features.
Has anyone experienced any issues with the select feature option?
AndrewWilson1
I'm having the same problem, on Portal. Did you resolve your issue, @BMCGIS?
