Custom Label Expression in AGO
2666
5
03-25-2021 09:04 AM
Labels (3)
MCouden
I have a field that has numbers and zeros. I want to label the the numbers as is but the zeros need to label as the word "pending". I know the start of the code is $feature(AADT_2020_Label) which will label the number. How do I make the expression if AADT_2020_Label equals zero label as pending? I've tried just putting pending in the text field but for some reason it is not liking it.
MCouden
There's still an open parentheses in the return  feature with no closed parentheses. I took it out and it seems to be working. Thank you.
DavidPike
MVP Notable Contributor
if ( $feature(["AADT_2020_Label"]  > 0) {
return $feature(["AADT_2020_Label"]
else {
return "Pending"
MCouden
if  ($feature(["AADT_2020_LBL"] > 0)  {return $feature(["AADT_2020_LBL"]} else {return "Pending"}
I think there needs to be closed parentheses. I am getting the error of Parse Error:Line 1: Unexpected token {
DavidPike
sure:
if  ($feature["AADT_2020_LBL"] > 0)  {return $feature(["AADT_2020_LBL"]} else {return "Pending"}
MCouden
DavidPike
You're going to set the removal of an inadvertent parenthesis in the code I provided as the solution? 🙄
