CSV --> Hosted Feature Layer - No Time Settings (Yes, I got a date field!)
1614
02-26-2025 06:11 AM
MarcoOrlandi
Hello everyone,
It's almost all in the title: I have a csv, I formatted the time field as explained here https://doc.arcgis.com/en/arcgis-online/manage-data/work-with-date-fields.htm
When I imported the CSV, AGOL recognized the field as a DATE field, but once imported (without any error), the hosted feature layer properties page shows an empty space where the TIME SETTING enabling option should be.
I have done this hundreds of times.... any idea?
AustinAverill
I've encountered this before and it stemmed from the "time field" not being set in the service definition, even though there was a date field. You might check this.
MarcoOrlandi
Austin, thanks for the reply and the suggestion!
How do I check the service definition? I think I never did before (usually I just have to check that the field type is correct during the upload - see the screenshot)
Thanks!
JasonSmolinski
Try the following:
Go to your hosted layer's Details page.
On the left-ish side of that page click the point layer link.
On the right side of this next page, scroll down and you should see a time settings toggle, far right side.
MarcoOrlandi
Hi, that's the process I usually do and that's exactly the problem... there's no time settings toggle where it should be!
