Create Stream Layer on ArcGIS Online
4111
12-20-2015 06:13 AM
MohamedNabil
Can I create Stream Layer on ArcGIS Online, or I must have ArcGIS for Server with geoevent processor?
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi Mohamed,
I can confirm that you need to have ArcGIS Server with the GeoEvent extension to create stream services (which can then be consumed by client apps as stream layers).
Currently, ArcGIS Online only supports hosted tiled and feature services.
Hope this helps,
DanPatterson_Retired
Your best bet is to explore the ...ArcGIS Online Help | ArcGIS
and search by topic... ie. Search Result | ArcGIS
DerekLaw
Hi Mohamed,
Hope this helps,
