Community Maps Labeling Concern
2717
07-30-2015 12:13 PM
MalcolmEchaluce
Here's the scenario.  We have a government polygon that we want to capture that is also one of our points of interest.  The government data prep tool captures/processes the polygon and label (name), while the points of interest data prep tool simply captures/processes the label (name).  We want to capture the polygon and its label, but also have it as a point of interest.  Should we just do the government one and remove the points of interest for that feature or does the Esri processing that happens once we submit the data eliminate one so there isn't a doubling up in labels?  Seems like this would be a simple solution considering it's one feature at this time, but there's a chance that others may have several features that could very well have a conflict like this.
TamaraGrant
Malcolm,
It would be best if you removed the point of interest label for that feature to eliminate the possibility of the feature being labeled twice.
Thank you,
Tamara Yoder
TamaraGrant
Malcolm,
Thank you,
Tamara Yoder
