Changing date column from US to UK format
4152
03-01-2021 07:14 AM
DarrenDe_Lange
Hi there
I am needing to change date columns from US format (mm-dd-yyyy) to UK format (dd-mm-yyyy).
Can this be done on ArcGIS online or ArcGIS Pro?
Using the field calculator?
Thank you for any assistance.
jcarlson
A date field is actually stored as a timestamp, which is just an integer understood to be "seconds since some date".
In order to change how your date field displays in AGOL, go into the Configure Popups → Configure Attributes dialog in a webmap:
According to the Pro docs, the date field display is determined by your machine settings. I do wish that there were more formatting options for datetime fields in Pro.
- Josh Carlson
Kendall County GIS
GWGazza
https://pro.arcgis.com/en/pro-app/latest/help/data/tables/date-fields.htm
Dates are stored yyyy/mm/dd and displayed according to your windows system settings.
jcarlson
- Josh Carlson
Kendall County GIS
DarrenDe_Lange
Thank you Josh, your help is much appreciated.
ArmandFrançois
Hi Dear,
We do configure sometimes a lot of layers with date in a single webmap, and we would like to set up a defaut format. So we dont need to configure it all one by one. Do you know any way to do that ?
Best Regards,
Armand FRANCOIS
