Change Widget Background Color using ArcGIS Online Assistant
1048
02-19-2019 02:13 PM
ScottKaplan1
Is it possible to change the background color of a widget in ArcGIS Online Assistant? I want to change the white area to grey. If not through AGOL Assistant, then how would I go about customizing this?
Thanks!
widget background
RobertScheitlin__GISP
Scott,
   No this can not be done using AGOL assistant. You would have to deploy an app using WAB Developer to your own web server to be able to make this change.
