Basics
665
08-27-2010 10:35 AM
PeterSiska
I am looking for a shapefile of Europe and Russia (separately). I would like to add my own data to this map and make my own thematic maps. ArcView long time ago used to have them. Any help would be appreciated. Thank you.
MikeMinami
Esri Notable Contributor
You might check the ESRI Data & Maps group on ArcGIS.com
http://www.arcgis.com/home/group.html?owner=esri&title=ESRI%20Data%20%26%20Maps
There are layer packages in here that you can probably use. You need version 9.3 and above, I believe. I'm not sure these layer packages contains shapefiles, but if you need that, you can probably convert the data.
Good Luck,
Mike
