Basemap Gallery Empty Error?
950
01-30-2013 04:41 PM
DanAllen
When I open any arcgis online webmap (new or existing) within our ArcGIS Online Subscription, if I click on the Basemap button, it comes up with a blank box with no opitons to switch basemaps?  I have tried it on 2 different computers using chrome and IE.  Seems to make no difference.
Is this a known problem?  Is so what is the fix?
Dan
JonathanQuinn
Esri Notable Contributor
Can you go to Edit Settings for the organization > Map > Basemap Gallery and see what it's set to?
DanAllen
Hi Jonathan,
Thank you for your reply.  I just got off the phone with ESRI support.  The issue was twofold.  I had not filled in my organization name in settings, and my default basemap was somehow set to a private group with no maps.  Once I filled in my organization name and changed my default basmap to "esri default" the issue was resolved.  So your suggestion was the same as the esri support folks.
Thanks again
