Attribute Rules in ArcGIS Online
405
02-26-2026 05:02 AM
Labels (2)
EAndreatti
As more and more of our content becomes directly edited in ArcGIS Online, is there a plan to enable Attribute Rules for hosted feature services?  There have been previously asked questions on this topic, but it seems that they have not had responses in recent months.  Having this as an option would be extremely helpful for those that have the same types of attributes across many layers or need to move data across layers.
Some specific examples from my own work
- adding invert elevations from manholes to the up and downstream elevation fields in gravity main
- carrying the value of the water main diameter to the associated system valves.
- move lead service line data back into the service line layers.
GlenterpriseUK
Hi @EAndreatti,
I hope you are doing well.
There is an ArcGIS Idea for what you are requesting which I advise you to give kudos on, but also comment if you want Support for Attribute rules in ArcGIS Online
In addition to this, you can get in touch with Esri Support to have the Enhancement that is already logged for this added to your account so you can monitor the status and receive updates on when this feature will get implemented.
Regards,
Glen
