ArcGIS Online layer search
3307
12-08-2013 09:59 PM
SreejithA
I've created and published a layer in ArcGIS Online. Now I found that the layer I created is not available when it is searched for. What would be the reason for this? Is there anything else to do? Please help me out.
Thanks & Regards,
Sreejith. A
GIS Services
TimWitt
Correct, unless you name your map, save it and share it with everyone. Then your map, which contains your shapefile, can be found in the search.
TimWitt
Did you upload a zipped shapefile or did you upload a feature service via an organizational account?
If it is a zipped shapefile then you won't be able to find it, you can however make a map with it and use the shapefiles name as map name and make the map open to the public.
If it is a feature service, make sure you allow everybody to see it. You can adjust those settings in the details page of your feature service.
SreejithA
Thanks for the information. I've uploaded a zipped shape file created in ArcMap.
So wot i've understood from your reply is that, if only it is a feature service, then it'll be available in layer search unlike the case with the shape file, right?
TimWitt
SreejithA
Yes. That was an valuable advice. Thank you so much. Be in touch.
Sreejith. A
GIS Services
