ArcGIS iPhone App TOC
1357
08-13-2010 09:37 AM
WilliamBailey
I have successfully added a map service to ArcGIS Online and can view it via iPhone.
This service has Group layers, my question is: where is the TOC control on iPhone app that could be used to turn layers on/off?   I can only see those initially visible in MXD.
p.s. service is 9.3.1
MollyZurn
If you are asking about how to turn on/off layers from within a Web map, access the details of a map - the list of map layers are inside of the details. You can turn the layers on/off from there.
Molly
MikeMinami
Esri Notable Contributor
The iPhone app doesn't currently support turning on or off sublayers of a service. You can, however, turn the entire service on or off via the details of the map.
Mike
WadeGivens
Mike
Mike:
Is that something that will be supported in a later release?
Wade
MikeMinami
Yes, turning on/off sublayers is coming in the 2.0 release of the app, available in April. At that time, the new pop-ups in the web map will also be supported.
Mike
