ArcGIS.com: Can't time-enabled feature service
4968
9
12-05-2013 01:46 PM
KatieGaut1
    I'm trying to create a web application that uses a time-enabled layer.  I've uploaded the shapefile, published as a feature service hosted on ArcGIS.com (through a developer account).  In Desktop ArcGIS 10.2, I have no problem enabling time on a field that represents "sample year".  In ArcGIS.com though, I follow the below instructions (from ArcGIS.com help page), and there is no "Time Settings" option when I click the arrow icon next to the layer.  In fact, the "Layer" displays my file name, not separate layers as I was expecting to see.  Any thoughts or insights would be so very appreciated!  Thank you!  Katie
Publish a hosted feature service on ArcGIS Online. For more information, see Hosted feature services.
Log in to the ArcGIS.com website and click My Content.
Click the name of your feature service to view its item details.
In the Layers section of the page, click the small arrow icon next to the layer where you want to enable time and click Time Settings.
Check the box next to Enable time
Choose to record the time data as specific events in time or time ranges with a start and end time.
Choose the time field or fields in your data.
by Anonymous User
Not applicable
Hi Katie,
You'll have to republish the service. If you used a shapefile or Geodatabase feature class you can add a new Date field and calculate it, then publish again.
Hope that helps,
Andrew
TimothieBiggs
Is it a group layer?
KatieGaut1
Hi timothieb,
    No, it's not a group layer.  Any thoughts would be appreciated!
Katie
KatieGaut1
Anyone have any thoughts??  Thanks in advance!
by Anonymous User
Not applicable
Hi Katie,
Are the dates stored in a date field or in a text/string field?
Can you share your service with me so we can take a look?
Andrew
KatieGaut1
Hi Andrew,
   Yes - absolutely!  Thanks so much for taking a look.  The dates are in a string field.  Here is the service URL.  Please let me know if you have any other questions.  Again, thanks again.
http://services2.arcgis.com/VmLllxPKgIzlr2id/arcgis/rest/services/Stations_with_Basins_Service/Featu...
by Anonymous User
Not applicable
Hi Katie,
Hope that helps,
Andrew
KatieGaut1
Hi Andrew,
   Just to be sure I understand - the date field needs to be reformatted as Date vs string, then republished?  Thanks!
Katie
by Anonymous User
Not applicable
Correct!
Andrew
KatieGaut1
Andrew,
   Consider my arms reaching through the computer screen to give you a giant hug!  Thank you so much.
Katie
