I have a layer of locations with a related table that contains 'calls for service' to a given location by police, fire, or code enforcement staff. I want to include in the pop up a breakdown of the types of alls made to each location, including the number of each unique type and a summary of a points score applied to each call based on the severity of the call type (for instance homicides get a 10, wiring infractions a 1). I think I can do this using a combination of the GroupBy function and FeatureSetByRelationshipName function. However, I keep running into a problem with the GroupBy syntax where Arcade flags the GroupBy statement and says it is an invalid variable assignment. I've modeled this after examples provided and can't figure out what i am missing in my code which is below. Any thoughts?
var CallsByType = GroupBy(FeatureSetByRelationshipName($feature, "AdaptLocationCallDetails"),
{name:'Department', expression:'BU_SOURCE'}
{name:'Type' , expression:'CALLDESCRIPTION'}
{name:'Total',expression:'1',statistic:'COUNT'}
{name:'Points',expression:'POINTVALUE',statistic:'SUM'}
