Arcade syntax question: checking if value is in a list
3270
08-17-2020 06:57 AM
Katie_Clark
MVP Regular Contributor
I am hoping this is a fairly simple question but I'm just a bit unclear on the syntax for Arcade and haven't been able to find the answer I need.
I want to return a certain value based on whether the county name is in a predefined list or not.
Something like this:
var counties = ['County1', 'County2']
if ( $feature.NAME IN counties ) {
return "Processed"
else {
return "Not Processed"
Thanks in advance for any guidance!
Cheers,
KC
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Tags (5)
JoshuaSharp-Heward
Not sure if this is the offical way of doing this but if you use indexOf(list, value) and the value isn't in the list it returns a -1, so you can set up a little switch using it! See below:
IIF(indexOf(counties, $feature.NAME) != -1, "Processed", "Not Processed")‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaSharp-Heward
Katie_Clark
Thanks for the quick reply! That works!
Best,
Katie
